Electrical Bathroom Vanity Light Fixture - Electrical - DIY Chatroom Home Improvement Forum
Old 09-29-2010, 11:34 AM   #1
Electrical bathroom vanity light fixture
I recently purchased a new vanity light fixture to put up in my master bathroom. the problem I am having is that the curcuit breaker keeps tripping when I turn the bathroom light on....
I have one yellow wire and two white that are from the wall.... and two white wires and two black wires that are on the new vanity light fixture, and the ground wire is attached to the light fixture ...
I attached the white fixture wires to the white wall wires, and the black fixture wires to the yellow wall wire, and the ground to the ground screw to the light fixture ... Did I wire this wrong and if so how should it be wired..
HEMMY1244 is offline   Reply With Quote
Old 09-29-2010, 11:39 AM   #2
joed's Avatar
Rewards Points: 12,858
How was the old fixture wired? It sounds correct. Does it trip as soon as you turn on the breaker or when you turn on the switch?
Old 09-29-2010, 12:23 PM   #3
Yes the old fixture was wired exactly the same... And yes as soon as you flip the light switch the the lights pop and the power is then tripped in the curcuit pannel
Old 09-29-2010, 05:32 PM   #4
joed's Avatar
Sounds like a wire shorted or pinched in a clamp to short to ground.
Old 09-29-2010, 07:40 PM   #5
Just to try:
On wires from light fixture: Attach only 1 black (to yellow from wall) and paired 1 white to white from wall. If trips, try other black/white from fixture. If works ok with one light, the other has a short.
diyorpay is offline   Reply With Quote
Help How to Wire Bathroom "Fan Heater Light Night-light" unit, and questions Tryvidy Electrical 9 06-18-2012 02:37 PM
Relocating a light fixture Eclipse99 Electrical 5 02-27-2010 10:04 PM
How much distance should the vanity top and the electrical outlet in the bathroom? Tobeyone Electrical 2 02-03-2010 11:12 AM
bathroom remodel at a stand still becuase of floating vanity installation diy'er on LI Kitchen & Bath Remodeling 10 11-23-2009 01:12 PM
Replacement Light Fixture - Speed Wire Clip? nick4597 Electrical 4 01-03-2009 12:49 PM
