Electrical Basics - Electrical - DIY Chatroom Home Improvement Forum
Old 02-12-2012, 01:51 PM   #1
Axhammer's Avatar
Electrical basics
I'd like to upgrade my garage electrical capacity, however I am limited when it comes to electrical knowledge. Can anyone recommend a god book to read to get moving in the right direction?
Pure-Pontiac
"See ya at the drags"
Moyock NC
Axhammer is offline   Reply With Quote
Old 02-12-2012, 02:06 PM   #2
Axhammer's Avatar
My house has a 225 amp main breaker. A 60 amp breaker supplies power to my detached garage. I'd like to step up to 100 amps.
Pure-Pontiac
Moyock NC
Old 02-12-2012, 02:16 PM   #3
Rewards Points: 87
I studied a lot from Home Depots version of Electrical for Dummies. It started out with all the basics, and goes from there to more complicated things.
myowneq is offline   Reply With Quote
Old 02-12-2012, 03:00 PM   #4
I=E/R
a7ecorsair's Avatar
You already have 60 amp service to the garage so why do you feel you need 100 amp service?
Wiring Simplified by Richter, Schwan, and Hartwell
a7ecorsair is offline   Reply With Quote
Old 02-12-2012, 03:12 PM   #5
Axhammer's Avatar
I have a larger air compressor I picked up used and I have a 110 volt mig. I am planning for a lift and a plasma cutter and a TIG also...
Old 02-12-2012, 03:18 PM   #6
I'd browse the book section of a store like HD/Lowes and pick up something that looks good and put some time to reading it.
For myself I want a nice detached garage one day and personally I'd run a 60A subpanel to it, I plan on doing this in buried conduit.
Getting a copy of your local jurisdiction electrical code book might be worth it if you plan on doing alot of repairs, to do things right you need to get a permit pulled and you'll need to get jobs inspected and you'll need to know the relevant codes (me thinks). In theory at least. And thats how I plan on doing it all. I have a copy of my provincial electrical code book and I can quickly look up ampacity of conductors, how many wires of a certain size in a conduit, derating factors on the conductors, what size ground I will need for a job, how deep to bury conduit and any other restrictions. You might not necessarily need conduit to run underground but you might need special direct burial wire and you might have to bury it deeper.
A home depot type book can give you the basics but you'll probably need a codebook as well and they're expensive but they allow you to do things properly and safely and pass inspection.
mdo11 is offline   Reply With Quote
Old 02-12-2012, 03:18 PM   #7
Axhammer's Avatar
I have a water softner and two well pumps in the garage, one for the tap water and the other for the HVAC system.
Proper way to ground a subpanel chieftaing Electrical 25 04-03-2011 10:22 AM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 06:46 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 09:48 AM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 02:42 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
