Old 10-20-2009, 05:57 PM   #1
Question
Electrical Baseboard Thermal Protection
Is it possible that over the years (25), the thermal protection switch gets weak and trips constantly?
I've noticed this problem since I installed digital thermostats throughout my home. A "Low Power" message appears off and on when the heat ramps up in the evening, this can only be caused by total power lost, which is not the case, or the thermal protection trips (for no reason)
This only happens on 2 of the 10 heaters I have. At first I thought the thermostat was the problem so I replaced it on one of the faulty baseboards and the problem still appears.
So if the thermal protection switch is weak, I'll start changing my baseboards throughout the house, they are pretty old after-all.
Any other suggestions?
Blade_316 is offline   Reply With Quote
Old 10-20-2009, 10:23 PM   #2
What is the model of your thermostat?
Willis
williswires is offline   Reply With Quote
Old 10-21-2009, 06:30 AM   #3
Honeywell RLV4300 5-2 Day Programmable
Old 10-21-2009, 07:21 AM   #4
Electrical Contractor
kbsparky's Avatar
I would love to have an Amprobe handy to see how your BB units are behaving.
It sounds plausible that the thermo cut-out is acting up and disconnecting the unit causing the symptoms you have described.
Try replacing one of the offending units, and see if you obtain desirable results.
-KB
Old 10-21-2009, 07:33 AM   #5
I'm almost certain it is. Right before I'll see the "Low Power" message I hear a big <<Click>> from the BB. After a few minutes I hear another <<Click>> and the message disappears.
Old 10-22-2009, 06:51 AM   #6
kbsparky's Avatar
Yup. That click is the thermo cut-out. You could replace the cut-out IF you could find a new one. Or replace the entire unit, as originally stipulated.
-KB
Tags
baseboard, digital, electrical, protection, thermal
Electrical outlet over Hot water baseboard redrumliny Electrical 5 09-04-2009 07:11 PM
Baseboard dilema Allyson Flooring 5 09-04-2009 09:30 AM
Electrical box replace,addiitions, city permits and looking for an electrician ramchy Electrical 3 08-02-2009 12:12 PM
how to wire up electrical baseboard heaters mmd21 Electrical 13 12-05-2008 09:11 AM
Electrical consumption of baseboard heater CowboyAndy Electrical 7 03-24-2008 08:27 PM
