Electrical Automation - Electrical - DIY Chatroom Home Improvement Forum
Old 01-07-2013, 11:44 AM   #1
electrical automation
Anyone knows of a good automation program for a 2500 ft house. Thanks for the help
RAUL HIDALGO is offline   Reply With Quote
Old 01-07-2013, 01:12 PM   #2
Missouri Bound's Avatar
For what, lighting, appliances, heat? Start with X10
Do you want it your way or the right way?
Old 01-07-2013, 01:19 PM   #3
It'll be general lighting. No appliances
Old 01-07-2013, 01:20 PM   #4
Its Gen. Lighting no appliances
Old 01-07-2013, 02:25 PM   #5
Rewards Points: 744
For cheap gear : X10
For great gear : Insteon
Seattle2k is offline   Reply With Quote
Old 01-07-2013, 02:37 PM   #6
Thanks man ill look up these brands
Old 01-07-2013, 02:43 PM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 2,124
As noted above....x10 is going to be on the cheap side....about par to Harbor Freight tools....
As another referece....try out SmartHome
http://www.smarthome.com/_/index.asp...FcaiPAodO3AAHQ
One other note.....a lot of the automation switches require a neutral at your switch box, so be cogizant of the wiring needs for the modules.
And....if you do put something together....do the rest of us a favor and do a thread on it and share what you learned.....I'd much rather learn from someone elses mistakes and successes.....
Old 01-07-2013, 02:53 PM   #8
Sure ill keep youguys up to date with the installation thanks
Old 01-07-2013, 04:19 PM   #9
Rewards Points: 108
I've been in process of automating my house with a combination or z-wave and insteon and the biggest issue for me has been with dimmers after the cost. Not all dimmers are created equally if you plan to use them. Incandescent ones (the cheapest) generally don't work well with LEDs mainly due to them using less power than the minimum rating for the switch, unless your dimmer also has a neutral wire or you want to get creative adding resistors to simulate the load. Also if you have fancy fixtures that use a transformer box you need to be aware of the transformer type (Magnetic Low Voltage (MLV) or Electronic Low Voltage (ELV)) or you could blow the switch, the fixture, or both. I got bit by that and ended up having to spend almost $200 for a single ELV switch.
If you don't care about dimmers then it doesn't really matter because it's just an on-off relay
zolakk is offline   Reply With Quote
Old 01-07-2013, 08:04 PM   #10
deverson's Avatar
Rewards Points: 77
I've had X10 for over 30 years. I've had Insteon for over 5 years. Insteon is superior to X10. Very few problems and all have been with the software. I've lost a couple of Insteon devices early on but were replaced under the 2 year warranty without a problem. I've installed insteon in homes where the customer doesn't want to rip down an entire ceiling. and installed it in a second home with the six button scene controller. Eliminates a lot of hassle and looks a lot better than X10
deverson is offline   Reply With Quote
Old 01-07-2013, 08:16 PM   #11
Rewards Points: 240
I hate X10. Very unreliable. I have a bunch of UPB devices and have few problems with them. Mine are driven by an HAI system, but you can get simpler and less expensive timer systems from PCS or Simply Automated.
fa_f3_20 is offline   Reply With Quote
Old 01-07-2013, 08:28 PM   #12
Thanks for all the feedback you guys helped a lot. With so many options ill just let the client decide
Old 01-07-2013, 09:06 PM   #13
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
If you are going to be working as a contractor, you should learn to do your own homework instead of relying on a DIY website.
Old 01-07-2013, 09:35 PM   #14
What's wrong with asking about a reliable brand its not like I'm asking how to do it I'm sure even you have been helped once or twice
Old 01-07-2013, 10:05 PM   #15
Rewards Points: 6,652
A wife, yourself, or your kid turning off the light switches as you leave or enter the room.
2500sqft is not that large of a house.
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 06:46 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 09:48 AM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 02:42 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Usefull Electrical Web Sites PaliBob Electrical 1 02-03-2009 10:49 AM
