electrical
Most likely you have:
1) Feed in
2) Feed out
3) Switched load #1
4) Switched load #2
You'll have to experiment with the other 3 wires, to determine whether they represent switched loads, or one that should remain on regardless of what those switches are doing.
Then, you'll have to connect the wires together that represent the feeds (in and out), and connect pigtails from there to feed your switches.
-KB
Life is uncertain -- eat dessert first!! To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
