Electrical - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-09-2011, 09:52 PM   #16
Rewards Points: 1,448
Household current wants to return to the pole transformer. Lightning wants to go to the (real) ground or earth. Hence the ground rod or ground plate.
Now a lightning bolt can be thousands of amperes, enough to melt a #6 wire. But the National Electric Code specifies (for most services) a #6 wire so I do not know the theory behind that.
Old 03-09-2011, 09:57 PM   #17
Electrical Contractor
kbsparky's Avatar
The grounding electrodes are there for things like lightning strikes. They are NOT there to assist in short circuit conditions in your premises wiring.
You can hook one of your hot lines directly to a ground rod, and it will just bleed electricity into the ground, running up your electric bill.
ASSUMING a ground rod has a resistance of 25 Ohms, then a 120 Volt line connected to it would draw 4.8 Amps --- much less than what is required to trip out a 15 Amp circuit breaker. IT ain't there to trip the breaker(s) for short circuits, but to give lightning and other catastrophic events a place to discharge.
-KB
Old 03-09-2011, 10:00 PM   #18
I=E/R
a7ecorsair's Avatar
Jeters, go back and read post #9. The grounding electrode has nothing to do with current flow.
a7ecorsair is offline   Reply With Quote
Old 03-09-2011, 10:00 PM   #19
kbsparky's Avatar
Originally Posted by AllanJ View Post
...a lightning bolt can be thousands of amperes, enough to melt a #6 wire. But the National Electric Code specifies (for most services) a #6 wire so I do not know the theory behind that.
For the most part, a lightning bolt will not melt a #6 wire (too short a duration), but made electrodes (such as ground rods, plates, pipes, etc) can't dissipate any more juice than a #6 can carry, hence the Code limitation on that wire size. Installing a larger wire size is a waste of resources.
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
SD515 (03-10-2011)
Old 03-09-2011, 10:06 PM   #20
Thanks everyone for the replies , these forums are very helpful and interesting, one thing I do know is that this home inspector that made the original post has to be just confused by now, thanks again, take care.
Jeter is offline   Reply With Quote
Old 03-09-2011, 10:10 PM   #21
I=E/R
a7ecorsair's Avatar
Originally Posted by Jeter View Post
They wouldn't want every short relying on the main neutral in residential, the #6 would take it to the plate unless theres a big short where the amprage exceeds the panel rating, (barley happens) then the neutral would take It, right? Just wondering,
And what will happen with the current that "goes to the plate?" It has to get back to the source.
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 07:46 AM
Changing from Electrical Cook Top to Electrical Range EkS Electrical 24 06-22-2010 11:43 AM
Electrical Engineer allowed to do Electrical work? SarahJennifer Electrical 48 09-21-2009 09:15 PM
Slight electrical current in bathroom faucet water + other unusual electrical events story Electrical 9 09-16-2009 11:28 PM
Electrical box replace,addiitions, city permits and looking for an electrician ramchy Electrical 3 08-02-2009 12:12 PM
