Electrical - Electrical - DIY Chatroom Home Improvement Forum
Old 02-22-2011, 09:49 AM   #1
electrical
I put a new air conditionair in and the circut breaker trips? I pulled an old 20 amp breaker out (crouse hinds) do i need a 30 amp breaker and wiring also ? and what gauge wire ty
Takes is offline   Reply With Quote
Old 02-22-2011, 09:51 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 554
Whats the specs on the ac?
What else is on the circuit?
You just can not change to a 30 amp breaker.
jbfan is online now   Reply With Quote
The Following User Says Thank You to jbfan For This Useful Post:
Takes (02-22-2011)
Old 02-22-2011, 10:04 AM   #3
elactrical
1800/17200 BTU---2050/1960 watts 230/208 Volts hampton bay8799760320 ---h2-60 tyvm nothing on the circut it on it's own line tyvvm
Old 02-22-2011, 10:16 AM   #4
elecreical
1800 /17200 BTU 230/208 Volts 2050 watts direct line to box h2-60
Old 02-22-2011, 10:19 AM   #5
elecrrical
nothing on the line /18000 BTU 230 Volts/2050 watts h2-60 tyvm
Old 02-22-2011, 11:02 AM   #6
Rewards Points: 530
Electricians?
watts/volts=amps, in this situation, right?2050/220=9.3? Can that be right?
Or do you have to consider startup amps when figuring the size of cable and breaker?
I always thought #10 wire with 30 amp breaker for 240 ac's. If you consider the startup amps that would seem right to me. Or, does the capacitor make up for the startup amps; therefore, not requiring the sizes I mention?
Btw, shouldn't the amps be on the unit somewhere?
The Following User Says Thank You to boman47k For This Useful Post:
Takes (02-22-2011)
Old 02-22-2011, 11:07 AM   #7
Originally Posted by boman47k View Post
Electricians?
9.2 Amps to 9.9 Amps
Old 02-22-2011, 11:08 AM   #8
ty I'm thinking the same with the 30 amp with 10/3 wire
Old 02-22-2011, 11:45 AM   #9
Rewards Points: 530
Takes, I am not an electrician, so you might want to wait until one responds to your question to be on the safe side.
Takes (02-22-2011)
Old 02-22-2011, 11:49 AM   #10
Takes /bowman
Old 02-22-2011, 12:08 PM   #11
I=E/R
a7ecorsair's Avatar
Was the circuit breaker you removed a two pole breaker - two wires connected to it?
a7ecorsair is offline   Reply With Quote
Old 02-22-2011, 12:25 PM   #12
Yes a hot & neuteral and ground !
Old 02-22-2011, 12:32 PM   #13
Scared Electrician
Saturday Cowboy's Avatar
hot and neutral or 2 hots using the white wire as a hot? (were the black and white wire landed directly on the breaker?)
also what size is the wire? 12ga?
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
The Following User Says Thank You to Saturday Cowboy For This Useful Post:
Takes (02-22-2011)
Old 02-22-2011, 01:05 PM   #14
Hot & neutral 10 gauge wire tyvvm
Old 02-22-2011, 01:07 PM   #15
I was told by an union members who's #1 in the union as far as teck work he said to run 10/3 wire using the blk & Red and ground out from what i understand ?? I'll get back to him ty
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 06:46 AM
Changing from Electrical Cook Top to Electrical Range EkS Electrical 24 06-22-2010 10:43 AM
Electrical Engineer allowed to do Electrical work? SarahJennifer Electrical 48 09-21-2009 08:15 PM
Slight electrical current in bathroom faucet water + other unusual electrical events story Electrical 9 09-16-2009 10:28 PM
Electrical box replace,addiitions, city permits and looking for an electrician ramchy Electrical 3 08-02-2009 11:12 AM
