Electrical - Electrical - DIY Chatroom Home Improvement Forum
Old 02-14-2011, 01:53 PM   #1
electrical
I am trying to put a furnace in my garage but only the fan runs I don't want a thermostat as I will shut off when temp is comfy, but furnace has a thermostat at the top of the furnace but can't figure how to wire it
johnp1153 is offline   Reply With Quote
Old 02-14-2011, 02:02 PM   #2
Rewards Points: 1,442
The thermostat on top of the furnace may be there to monitor the temperature inside the boiler. Can you show us a picture?
It is not good to set up a furnace to run using only a manual shutoff. You might forget and leave the room and then the furnace runs forever.
Old 02-15-2011, 11:52 AM   #3
Rewards Points: 78
The furnace will not operate until you make the circuit through the switch/T-Stat on top. Theres a reason for the T-Stat. Safety. And thats why it will not run until you find out how to wire a furnace.
Call someone.
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 07:46 AM
Changing from Electrical Cook Top to Electrical Range EkS Electrical 24 06-22-2010 11:43 AM
How to install new electrical box without attic access gilmores33 Electrical 10 02-14-2010 08:46 PM
Slight electrical current in bathroom faucet water + other unusual electrical events story Electrical 9 09-16-2009 11:28 PM
Electrical box replace,addiitions, city permits and looking for an electrician ramchy Electrical 3 08-02-2009 12:12 PM
