Electrical - Electrical - DIY Chatroom Home Improvement Forum
Old 11-05-2010, 11:34 AM   #1
Electrical
I have a has fireplace that is turned on by a light switch. It only turns on the unit...doesn't control the height of the flame. What I want to know is can I change the light switch to a remote switch and if so will a dimmer remote switch work since that is all I have been able to find
Carlton1 is offline   Reply With Quote
Old 11-05-2010, 11:39 AM   #2
Mad Scientist
No. You probably won't find a way to remotely adjust the height of the flame, however a lot of gas fireplaces do have the option of a remote with on/off control and thermostat. This would be an option specific to your fireplace, you'll have to check with the manufacturer to see what's available.
McSteve is offline   Reply With Quote
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 06:46 AM
Changing from Electrical Cook Top to Electrical Range EkS Electrical 24 06-22-2010 10:43 AM
How to install new electrical box without attic access gilmores33 Electrical 10 02-14-2010 07:46 PM
Electrical Engineer allowed to do Electrical work? SarahJennifer Electrical 48 09-21-2009 08:15 PM
Electrical box replace,addiitions, city permits and looking for an electrician ramchy Electrical 3 08-02-2009 11:12 AM
