a neutral is present at the light circuits, then 120v is available using one of the hot (black or red) wires with respect to the neutral (white) wire,
would be good if you can split the new lights (half on one hot wire, half on the other) so as to balance the new light load
I see how this would be done from a power standpoint, but is there a single switch generally available that would allow control of all three (240v, leg 1, leg2) sets of lights? Could you control this with a DPST-type switch?
