Electrical - Electrical - DIY Chatroom Home Improvement Forum
Old 04-22-2009, 08:49 PM   #1
electrical
I want to add a sub- panel in my garage from my main panel in the house, the garage is unattached and it must run over head. I want to put in a 60 amp panel, my question is do I run a neutral and ground from the house panel like a 6666 se cable or put in a separate ground rod off the sub-panel and run a 666 se cable
mcinkansas is offline   Reply With Quote
Old 04-22-2009, 08:53 PM   #2
dSilanskas's Avatar
6666 se hmm interesting
dSilanskas is offline   Reply With Quote
Old 04-22-2009, 09:01 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,974
First off, this applies to all new posters. Put something more than "Electrical" in the title. This is the "Electrical" forum, I sure hope it is an electrical question.
OK, first off, WHY do you have to go overhead? I hope you realize this is much more difficult than underground.
Second, there is almost 100% change that you MUST run a "4-wire" feeder to the detached garage simply to meet code. In any case it is definitely a good idea.
No matter what, a detached structure supplied with a feeder MUST have a grounding electrode installed. Typically this is a ground rod (or two). If there is a metallic water pipe feeding the building that must be used as an electrode.
With the exception of the 4-wire feeder a detached structure get's treated basically the same as the supplying main building.
Old 04-23-2009, 11:54 AM   #4
I'll try to do better ..... do as I would supplying the main building so I bond the Grounded and the grounding conductors in the sub -panel .
Old 04-23-2009, 11:55 AM   #5
sub-panel in a detached garage
Old 04-23-2009, 11:58 AM   #6
How far is the garage? What loads are you going to have? You might want to consider voltage drop.
I would bury the line, aerial is much more difficult.
Ground from rods and pipe go to sub panel ground bar. You still need to run a ground to the house.
Neutrals are isolated from the frame and ground bar in a sub panel.
rgsgww is offline   Reply With Quote
low-voltage and electrical wiring sharing same stud space jheavner Electrical 21 10-06-2011 11:16 AM
Electrical Engineer allowed to do Electrical work? SarahJennifer Electrical 48 09-21-2009 08:15 PM
Usefull Electrical Web Sites PaliBob Electrical 1 02-03-2009 10:49 AM
Electrical Box near Shower Valve dasajame Electrical 3 07-07-2008 06:46 AM
2 Prong Electrical mjcongleton Electrical 10 04-16-2008 08:59 AM
