electrical
trying to hook up a well with capacitors have 2 line wires 2 load wires 2 capacitors wires I know 2 lines go to L1 & L2 2 loads go to T1 & T2 were do the 2capacitor wires go L1&2 or T1&2
there hopefully is a diagram on the motor frame to show you.
Are you dealing with one of those well pump control boxes?
One of the capacitors should be for the starting winding of the motor, the other one for running the motor. There should also be some sort of overload buttons there that are connected as well. What is the HP rating of your motor, and model of the control box? |
| All times are GMT -4. The time now is 07:30 AM. |
