Electrical - Electrical - DIY Chatroom Home Improvement Forum
Old 11-23-2008, 11:15 AM   #1
electrical
Is there a code requirement foor the location of the outdoor electric meter? I am installing an underground meter duct to be connected to a new service panel. Is there a minimum height for the new service panel?
HIHOKC is offline   Reply With Quote
Old 11-23-2008, 11:34 AM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
the meter location in most areas is determined by the power company. Most POCO's I have dealt with like it about 5- 5 1/2 feet off the ground. In my area, the POCO even determines where on the house it is installed. They are not jerks about it generally but once in awhile they make a person mount it in an unwanted location.
panel mounting height. max height is 6'7" to top breaker. There is no minimum but just don;t mount it at the floor if there is any possibility of flooding it.
Old 11-23-2008, 04:40 PM   #3
Not really...If it doesn't have a disconnect it must be close enough to the first disconnect...no unfused service conductors more than 5ft into a structure...
rgsgww is offline   Reply With Quote
Old 11-23-2008, 05:44 PM   #4
Electrician
Where did you get that code from?
chris75 is offline   Reply With Quote
Old 11-23-2008, 07:14 PM   #5
nap
You talking to me?
nap's Avatar
I'm a callin' ya out. (that's the closest I could get to John Wayne with 2 hip holsters)
Please post support of your 5' claim.
actually the code (NEC) states a readily accessible location nearest the point of entrance of the service conductors. You may be under a different code.
Old 11-23-2008, 07:15 PM   #6
Electrician
The code does not give a length limit, only says an accessible point nearest the point of entrance. This is a judgement call by the AHJ.
Some want the panel back to back with the meter, some will allow 5', 10' or more depending on the situation.
EBFD6 is offline   Reply With Quote
Old 11-23-2008, 07:17 PM   #7
Electrician
How dare you type faster than me and beat me to the punch!
Old 11-23-2008, 08:25 PM   #8
I just read through the codes...I wasn't surprised that it wasn't there...
What's the ICC Electrical Code? Chuck Electrical 7 02-20-2013 11:19 AM
low-voltage and electrical wiring sharing same stud space jheavner Electrical 21 10-06-2011 12:16 PM
Electrical Box near Shower Valve dasajame Electrical 3 07-07-2008 07:46 AM
2 Prong Electrical mjcongleton Electrical 10 04-16-2008 09:59 AM
Please Help - Weird electrical issue affecting home network sxpsxpsxp Electrical 23 02-03-2008 12:42 PM
