#1 |
Electrical
I have a plug-in outside my front door-used to work -now doesn"t-We have tried throwing the breakers-pushing the GFI's -I looked inside the plug-in-it seems to be attached to the wiring-any ideas on how to remedy this?? Thanks
#2 |
My License Ain't 4 Sale..
Electrical
Is this outlet a GFCI itself? And do the receptacles on the other side of the wall nearest this one have power? It is likely that the receptacle itself has gone bad if it is a GFCI, but you need a way to test for power, like a volt meter, to be sure.
#3 |
Moderator
Electrical
My first step would be to replace the GFCI device if that is in fact what you have outside. You should use a receptacle tester or a meter to determine if it is getting power or not. Turn off the power to make it safe, take good notes on how the existing receptacle is hooked up, remove it and re-install a new one. GFCI's aren't exactly military grade hardware, and they do go bad fairly frequently.
If that doesn't work we can explore some other options. |
| Display Modes | |
| low-voltage and electrical wiring sharing same stud space | jheavner | Electrical | 21 | 10-06-2011 12:16 PM |
| hooking up dryer....bronx ny code | SURFBUG | Appliances | 6 | 10-14-2008 10:41 PM |
| Electrical Box near Shower Valve | dasajame | Electrical | 3 | 07-07-2008 07:46 AM |
| 2 Prong Electrical | mjcongleton | Electrical | 10 | 04-16-2008 09:59 AM |
| OK to put electrical outlet into storage area under stairs? | melanie_s | Electrical | 1 | 12-29-2007 05:09 PM |
