Electrical - Electrical - DIY Chatroom Home Improvement Forum
Old 07-17-2008, 12:40 PM   #1
electrical
I am renovating an existing apartment above our garage. I want to install split receptacles in the kitchen using as a power source an existing 240 outlet on double 20 amp breaker. Wires runing to the outlet are in a red sheathed wire consisting of one red, black and ground - no white neutral. Wire gauge is 10. Can I connect spit receptacles without a neutral?
ghufnagel is offline   Reply With Quote
Old 07-17-2008, 12:46 PM   #2
No. Was this old wire for a cooktop or wall oven?
jerryh3 is offline   Reply With Quote
Old 07-17-2008, 12:47 PM   #3
Electrician's Helper
Pudge565's Avatar
Rewards Points: 150
Send a message via AIM to Pudge565
This post scares me if you don't know what you are doing call an electrician. But since it is a diy site no you can't have a 120v outlet without the neutral. Since it is an apartment I would call an elctrician.
Pudge565 is offline   Reply With Quote
Old 07-17-2008, 12:54 PM   #4
Panel marking says wiring was used for a sewing machine. Receptacle has two horizontal slots plus ground.
Old 07-17-2008, 01:06 PM   #5
Must of been one hell of a sewing machine. No luck with using that circuit as a Multiwire branch circuit.
Old 07-17-2008, 01:09 PM   #6
Rewards Points: 266
Thats a NEMA 6-15. It is for 240 volts and 15 amps. The cable you describe is a cable that is made for 240 volts only. (it has no white wire) which tells me you are from Canada. (we don't have that style cable in the US) I also believe it is illegal for you to reidenify one wire as a nuetral to reuse the cable as a 120 volt circuit. You would have to rewire with a 3 wire cable in order to have a mulitwire circuit.
junkcollector is offline   Reply With Quote
Old 07-17-2008, 01:09 PM   #7
Rewards Points: 81
Thats one heckuva sewing machine (enough power for 5hp)
Must have been for sewing chainmail
daxinarian is offline   Reply With Quote
Old 07-17-2008, 01:16 PM   #8
Thanks for the info. I'll clip the wires and run a new 14/3
Old 07-17-2008, 04:46 PM   #9
Electrician
If its a real kitchen then you have to use #12 AWG.
chris75 is offline   Reply With Quote
Old 07-17-2008, 04:55 PM   #10
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
I would assume the OP is in Canada. We don't have that "240v cable" here in the US.
Old 07-17-2008, 05:15 PM   #11
That's correct. What I find interesting is that even when I disconnected one of the terminals on the recepticle, both red and black were live. How does this work without a neutral?
Old 07-17-2008, 05:18 PM   #12
I don't know about real kitchens but in Ontario, 14/3 is code for split receptacles in kitchens
Old 07-17-2008, 06:43 PM   #13
A 240v circuit is a line-to-line circuit. NO neutral is involved.
What's the ICC Electrical Code? Chuck Electrical 7 02-20-2013 10:19 AM
Electrical Box near Shower Valve dasajame Electrical 3 07-07-2008 06:46 AM
2 Prong Electrical mjcongleton Electrical 10 04-16-2008 08:59 AM
Please Help - Weird electrical issue affecting home network sxpsxpsxp Electrical 23 02-03-2008 11:42 AM
Code Question: Electrical and plumbing ELurie Electrical 2 08-22-2007 08:55 PM
