Old 07-14-2008, 11:59 AM   #1
noclue
Question
electrical
i need to run from a 200 amp panel to an out building 200' away. what size wire and conduit will i need. maximum amps of any of my equipment being used in the building is 40amps. the equipment is protected with 40 amp breaker which has never needed to 'kick out' during use of the equipment. Thank you
noclue is offline   Reply With Quote
Old 07-14-2008, 12:03 PM   #2
Power Gen/RS Engineer
electrical
What do you mean? Is there already an existing circuit? Please provide some additional details.
The very existence of flamethrowers proves that some time, somewhere, someone said to themselves,"You know, I want to set those people over there on fire, but I'm just not close enough to get the job done." - George Carlin
BigJimmy is offline   Reply With Quote
Old 07-14-2008, 08:07 PM   #3
noclue
electrical
bigjimmy, its a new building has a breaker box with a 40 amp breaker. the power supply is from a 200amp service (circuit breaker panel) 200 feet away in another building. i would like to go under ground to the new building with the correct conduit and wire.
Old 07-14-2008, 09:09 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
electrical
I don't get this at all.
WHERE is this 40A breaker? In the new building?
So you need a 40A feed to the new building? Or is the load 40A?
DETAILS! We need details.
Old 07-14-2008, 11:33 PM   #5
noclue
electrical
as my last reply stated the new building has a breaker box in it with a 40 amp breaker. it will supply power to a compressor that does not pull 40 amps at most it may pull 15 amps. i know it is over kill but i would like to produce 220 volts to this building to power the compressor.
Old 07-14-2008, 11:44 PM   #6
noclue
electrical
i can see where the confusion may be the equipment i am putting in the new building, it is being moved from the old building where it was protected with a 40 amp breaker. i installed a 40 amp disconnect in the new building and now need to know what size the conduit and wire should be to run power fron the old building to the new building where it will be located. approx 200 feet away
Old 07-14-2008, 11:49 PM   #7
Electrician
electrical
Whats the nameplate on the compressor say?
chris75 is offline   Reply With Quote
Old 07-14-2008, 11:59 PM   #8
noclue
electrical
thanks for your reply chris75, i am not home right now to check i believe it is max 12 amps ? i will check when i get home. that will be tomorrow. get back to you then if i am wrong.
Old 07-15-2008, 10:56 AM   #9
electrical
Ok, let's see if I understand...
You want to install a 2-p disconnect in your outbuilding for the sole connection of an air compressor. This will be fed from a 200A panel in your home (?) and you'd like to install u/g conduit and wiring between the two structures. Am I close?!
Old 07-21-2008, 10:58 PM   #10
noclue
electrical
that is correct and thank you for any info you can give . noclue
What's the ICC Electrical Code? Chuck Electrical 7 02-20-2013 11:19 AM
Electrical Box near Shower Valve dasajame Electrical 3 07-07-2008 07:46 AM
2 Prong Electrical mjcongleton Electrical 10 04-16-2008 09:59 AM
OK to put electrical outlet into storage area under stairs? melanie_s Electrical 1 12-29-2007 05:09 PM
Code Question: Electrical and plumbing ELurie Electrical 2 08-22-2007 09:55 PM
