Electrical - Electrical - DIY Chatroom Home Improvement Forum
Old 05-18-2008, 02:24 PM   #1
Electrical
I have a light in a bedroom that shuts off after about 30 minutes, then comes back on in about 20 minutes. Is the bulb too high of a rating for the fixture? I have never seen this before.
Gcommerford is offline   Reply With Quote
Old 05-18-2008, 03:30 PM   #2
Registered User
Termite's Avatar
Many lights have thermal cutoffs for when they get too hot. This is very common in recessed lights.
I would imagine that your bulb wattage is too high, and is therefore causing the light to shut off. Try a low wattage bulb and see if that takes care of it.
Old 05-18-2008, 04:05 PM   #3
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Also use the correct type of bulb. should be stated stated on the fixture the type and max wattage of the bulb
wirenut1110 is offline   Reply With Quote
Old 05-18-2008, 11:10 PM   #4
Electrical
I would have to agree with the thermal shutoff as I heard it click when the light shut off. I was in the room working and the light would go off every 30 minutes. Thanks so much for the help!!!
Old 05-18-2008, 11:22 PM   #5
Registered User
Termite's Avatar
Using too much light bulb for your fixture is an unsafe thing to do, despite the thermal shutoff. I would be sure to correct the situation before you have a big problem, and not just deal with the inconvenience.
Old 05-19-2008, 07:03 PM   #6
Electrical
The light in question is a recessed light. The fixture says to use a max 75W bulb, which was installed. I removed it anyway because I was a little concerned about the possibility of a fire hazard. I don't know why it would cut out with a 75W bulb in 75W fixture. Oh well, I guess it doesn't really matter anyway because I will be removing the recessed lighting and installing a ceiling fan .
Thanks Guys
Old 05-19-2008, 07:34 PM   #7
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
Just curious at this point. Was the 75 watt lamp the correct type? A standard incandescent lamp will overheat a recessed fixture, but the flat lens spot light type lamps the fixture calls for, will not over heat the fixture.
John
jrclen is offline   Reply With Quote
Old 05-19-2008, 11:23 PM   #8
Registered User
Termite's Avatar
Me too! What type of bulb was in there?
Old 05-28-2008, 07:04 PM   #9
Electrical
Sorry for the late reply guys. I did use a standard 75W incandescent bulb. Thats probably why I had the thermal cutoff. I looked at the fixture rating, but I didn't see any indication of a bulb type.
Old 05-28-2008, 07:55 PM   #10
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
Maybe a non-IC can with insulation too close?
Speedy Petey is online now   Reply With Quote
What's the ICC Electrical Code? Chuck Electrical 7 02-20-2013 10:19 AM
Can a homeowner perform electrical work in MA? dpd512 Electrical 77 04-11-2012 06:48 AM
2 Prong Electrical mjcongleton Electrical 10 04-16-2008 08:59 AM
OK to put electrical outlet into storage area under stairs? melanie_s Electrical 1 12-29-2007 04:09 PM
Code Question: Electrical and plumbing ELurie Electrical 2 08-22-2007 08:55 PM
