Electrical - Electrical - DIY Chatroom Home Improvement Forum
Old 03-21-2008, 10:43 PM   #1
electrical
What size wire do I need to hitch up a 7HP 240V 15A compressor with a run of 60'?
nonotoriani is offline   Reply With Quote
Old 03-21-2008, 10:56 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,824
Forget the HP. It is a false rating.
If the amp draw actually is 15 then 12/2 would be fine for that distance.
Old 03-22-2008, 11:45 AM   #3
joed's Avatar
Rewards Points: 11,588
7 HP and 15 amps is contradiction of terms. Like being fat and weighing 120 lbs. A true single phase 7.5 HP motor draws about 40 amps full load at 230 volts. 15 amp full load is more like 2 or 3 HP motor at 240 volts.
You need to refer to the compressor manual for the size of circuit required and the voltage. A 15 amp circuit requires #14 wire. A 20 amp circuit requires #12 wire..
Old 03-22-2008, 12:06 PM   #4
Rewards Points: 58
Does the Compressor have cord and plug on it. Most small compressors are designed to be plugged into a 20 amp recetacle. Plug it in.
As said above a true 7.5 Hp single phase motor at 240 volt will draw around 40 amps. There is no way the motor is 7.5 hp.
Old 03-22-2008, 03:56 PM   #5
If the compressor truly draws 15 amps, you will need a 20A dedicated line with #12/2 wire.
If it uses a standard type 3-wire plug, make sure the receptacle it's plugged into is rated for 20A, not one of the cheapie 15A ones. If it's a special plug, then obviously it will have the correct rating.
I always liked to use Hubble plugs/receptacles for heavy loads.
FW
fw2007 is offline   Reply With Quote
Old 03-22-2008, 09:19 PM   #6
Electrician
FW
I hate to be the one to break this to you, but a 15 amp and a 20amp receptacle have the same guts installed, just a different shell...
chris75 is offline   Reply With Quote
Old 03-24-2008, 11:01 AM   #7
Thanks for that info. I still prefer to buy the more expensive 20A, because the shell looks like it will take more "abuse".
Does what you say apply also to the Hubbel products? I would hate to think so, as they cost so much more.
Then, I have not seen any Hubbel standard duplexes. All I've seen and used were specialty devices.
FW
Old 03-24-2008, 11:14 AM   #8
A 15 or 20 amp "spec grade" receptacle is made EXACTLY the same.
The ONLY difference is the slot configuration.
Much of the cost difference is in supply and demand.
What's the ICC Electrical Code? Chuck Electrical 7 02-20-2013 11:19 AM
Can a homeowner perform electrical work in MA? dpd512 Electrical 77 04-11-2012 07:48 AM
Please Help - Weird electrical issue affecting home network sxpsxpsxp Electrical 23 02-03-2008 12:42 PM
OK to put electrical outlet into storage area under stairs? melanie_s Electrical 1 12-29-2007 05:09 PM
Code Question: Electrical and plumbing ELurie Electrical 2 08-22-2007 09:55 PM
