Electrical - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-02-2013, 06:24 PM   #16
Yes, I have voltage between one black and one white, nothing registers between the other corresponding wires.
Terimarie is offline   Reply With Quote
Old 06-02-2013, 08:05 PM   #17
Rewards Points: 512
Cap off the White neutral (the one with which you get 120v with the corresponding Black).
Wire nut the grounds together with a pigtail to the switch.
Put the Black Hot (the one that comes in with the neutral you capped off) on the Common (dark) screw.
Terminate the other two wires (B+W) on the other two screws. Doesn't matter which goes to which.
SEE BELOW POST
Installation is the Reverse of Removal.
Old 06-02-2013, 08:06 PM   #18
Rewards Points: 512
hold the above thought a min
The black tape on the white wire indicates that it is Hot, so it should go to the Common Screw, with the others going to the remaining.
Try this first.
Old 06-03-2013, 05:18 PM   #19
electrical
Too late, I tried it...and blew the switch. So, the white is the hot wire not the black?
Proper way to ground a subpanel chieftaing Electrical 25 04-03-2011 10:22 AM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 06:46 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 09:48 AM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 02:42 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
