Electrical - Electrical - DIY Chatroom Home Improvement Forum
Old 04-08-2013, 09:50 AM   #1
electrical
I tried to use my electric lawn mower yesterday and there was no power to the mower when plugged into the outlet. A test of the outlet indicated the ground and hot lead reversed, or OPEN GROUND wire. I checked another outlet on the back deck and received the same reading. Could an open ground on one outlet affect the second outlet in the same way?
kenSherman is offline   Reply With Quote
Old 04-08-2013, 09:51 AM   #2
Old 04-08-2013, 10:27 AM   #3
of course. If the previous outlet in the circuit has an open ground, then the next outlet in the circuit will also have an open ground.
It sounds like these are outside, so perhaps check and see if there is a GFI outlet somewhere along the way that has tripped.
fred54 is offline   Reply With Quote
Old 04-08-2013, 10:46 AM   #4
Rewards Points: 252
Reverse polarity would still produce 120 volts. An open ground while dangerous has nothing to do with no power. It would still work without a ground also.
I agree with the above post that if its an outside receptacle it IS on a gfci. If its in the garage it is SUPPOSED to be gfci protected.
Go and check every gfci in the house and outside and see if one has tripped? I found in a house recently a gfci receptacle in a bathroom feeding two more bathrooms and one outside receptacle. So the tripped gfci can be anywhere.
J. V. is online now   Reply With Quote
Old 04-08-2013, 07:07 PM   #5
joed's Avatar
Rewards Points: 13,762
Have you looked for a GFCI that is tripped?
Your reading could also be an open neutral.
The Following User Says Thank You to joed For This Useful Post:
Stubbie (04-08-2013)
Proper way to ground a subpanel chieftaing Electrical 25 04-03-2011 10:22 AM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 06:46 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 09:48 AM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 02:42 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
