Electrical - Electrical - DIY Chatroom Home Improvement Forum
Old 03-29-2013, 11:21 PM   #1
electrical
does 2 10 gauge wires = A 6 GAUGE
stevybobcat is offline   Reply With Quote
Old 03-29-2013, 11:28 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
nope
Old 03-30-2013, 03:21 AM   #3
Electrical Contractor
kbsparky's Avatar
The OP may be assuming that #10 wires may be paralleled to use for a 60 Amp load. After all, mathematically 2x30=60.
Problem here is paralleling of conductors can not be used in this manner with wire sizes smaller than #0 AWG.
-KB
Old 03-30-2013, 08:18 AM   #4
k_buz's Avatar
See, once you state that, he's gonna do it anyway.
The Following 2 Users Say Thank You to k_buz For This Useful Post:
jbfan (03-30-2013), stickboy1375 (03-30-2013)
Old 03-30-2013, 08:46 AM   #5
Master Electrician
Rewards Points: 3,678
Wouldn't that be 1/0 ?
brric is online now   Reply With Quote
Old 03-30-2013, 09:10 AM   #6
eastcoastsparky's Avatar
Rewards Points: 150
Anything larger then 1/0 may be parralled
eastcoastsparky is offline   Reply With Quote
Old 03-30-2013, 09:35 AM   #7
Master Electrician
1/0 or larger? Correct?
Old 03-30-2013, 03:34 PM   #8
kbsparky's Avatar
First of all: #0 and 1/0 are the SAME THING.
Second: You are permitted to parallel conductors 1/0 (#0) or larger.
-KB
Old 03-30-2013, 05:06 PM   #9
Master Electrician
That's what Iwas pointing out. I was just tying to be nice.
Proper way to ground a subpanel chieftaing Electrical 25 04-03-2011 11:22 AM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 07:46 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 10:48 AM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 03:42 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
