Electrical - Electrical - DIY Chatroom Home Improvement Forum
Old 12-24-2012, 01:35 AM   #1
Question
Electrical
Today 12-23-12 the main breaker kept kicking off, had a guy come out and the moan breaker has burnt into . Now the box is Murry, I did read where Murry had caused problems , had recalls , and don't make Murry anymore . It's cold and Christmas no power, so does anyone know about what I am talking about . thanks !i
Ibekatie is offline   Reply With Quote
Old 12-24-2012, 04:33 AM   #2
An old Tradesmen
Rewards Points: 6,928
Answers are given in the forum. Please don't ask for members to contact you directly, thank you.
Old 12-24-2012, 04:50 AM   #3
Electrical Contractor
kbsparky's Avatar
Some of the older Murray stuff is junk.
The newer Murray stuf is the same as Siemens, but a cheaper line.
-KB
Old 12-24-2012, 05:52 AM   #4
Lic Elect/Inspector/CPO
I agree.
Especially the red main breakerss
NJMarine is offline   Reply With Quote
Old 12-24-2012, 07:46 AM   #5
Rewards Points: 3,130
Sounds like you need to call an electrician. I suspect this problem is more than you can fix yourself.
Old 12-24-2012, 08:16 AM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
So, to answer your question directly I do know what you are talking about.
With that out of the way, WHAT are you looking for here????
What "guy" did you have come out? Did he not have, or can't get, a replacement breaker? Sound like that is what you need.
This is NOT a DIY repair.
Old 12-24-2012, 10:09 AM   #7
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
I've had to replace many murray main brakers for the exact reasons you mention. As was mentioned the panel is no longer made and replacing the main may not solve the entire extent of damage. Almost always there is damage to the bus bars due to the fact those murray main breakers are backfed and install directly to the panel bus bars. Your best bet (probably only choice) is a new panel.
And Speedy is correct do not atempt to replace as DIY whether new panel or replacement breaker. You absolutely must get the utility involved to remove power from the meter can and a permit with an inspection from the building codes department.
Old 12-24-2012, 10:15 AM   #8
UAW SKILLED TRADES
Stubbie's Avatar
An example
Proper way to ground a subpanel chieftaing Electrical 25 04-03-2011 10:22 AM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 06:46 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 09:48 AM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 02:42 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
