Electrical - Electrical - DIY Chatroom Home Improvement Forum
Old 11-13-2012, 11:58 AM   #1
electrical
i have a wire coming out of a junction box going to an outside light then a wire from outside light going to a switch below it to turn it on an off if switch is in off position is the power off going back to light or is there still power coming from junction box thank u
soapopera1 is offline   Reply With Quote
Old 11-13-2012, 12:03 PM   #2
Rewards Points: 13,228
Why are you asking? What is it your really trying to do?
Old 11-13-2012, 12:12 PM   #3
electrical
want to put junction box in between light and switch with out having to turn off main power to garage
Old 11-13-2012, 12:26 PM   #4
Licensed electrician
Rewards Points: 1,230
Why not just use the junction boxes that are there?
Old 11-13-2012, 01:07 PM   #5
junction box that is there has to many wires already would like to install new one for future use if need b
Old 11-13-2012, 01:54 PM   #6
joed's Avatar
Rewards Points: 11,962
You have a switch loop. The power is never completely off in any of the boxes. Only the black wire coming back from the switch goes on and off. The rest of the black wires in the light box and the white wire in the switch box are always live.
Proper way to ground a subpanel chieftaing Electrical 25 04-03-2011 11:22 AM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 07:46 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 10:48 AM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 03:42 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
