Electrical - Electrical - DIY Chatroom Home Improvement Forum
Old 10-11-2012, 01:33 PM   #1
tbone4469's Avatar
electrical
Is there a way to trace old lines without tearing down the whole ceiling? ??
tbone4469 is offline   Reply With Quote
Old 10-11-2012, 02:22 PM   #2
Rewards Points: 1,294
Some models of stud finders have that feature.
http://www.altex.com/Velleman-Live-W...2-P147552.aspx
danpik is offline   Reply With Quote
Old 10-11-2012, 03:56 PM   #3
Rewards Points: 24
What is your objective? I will probably not be back here for several days, but that's okay, because there are a lot more knowledgeable people here anyway, and, given some more details, they may be able to lend some additional suggestions. A good starting point might be to determine which devices are on which circuits; with that information, you may be able to visualize possible paths. If you are attempting to isolate a problem, keep in mind that, if done properly, wire connections will only be made inside of receptacle boxes, lighting box, or other accessible junction boxes.
Old 10-11-2012, 04:17 PM   #4
Oso954's Avatar
Rewards Points: 444
A stud finder might indicate the presence of an electrical wire. Often they do not. It is surely not accurate enough to trace a specific wire
Oso954 is online now   Reply With Quote
Old 10-11-2012, 06:39 PM   #5
Rewards Points: 12,878
Telling use what it is your really trying to do and why will come up with some better ansewers.
Old 10-11-2012, 08:35 PM   #6
Rewards Points: 1,418
You can buy a tone generating circuit tracer kit (toner for short). You clip one part on a wire end or screw terminal (power turned off please) and maneuver the other part about wall and ceiling surfaces to find the route of the wire.
Proper way to ground a subpanel chieftaing Electrical 25 04-03-2011 11:22 AM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 07:46 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 10:48 AM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 03:42 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
