Electrical - Electrical - DIY Chatroom Home Improvement Forum
Old 01-20-2008, 09:56 AM   #1
electrical
I have a 200 amp breaker box. I have to run the wire to from the meter to the breaker box at a distance of 150 yards underground. What size thhn wire do I need to run this?
sddlebum is offline   Reply With Quote
Old 01-20-2008, 10:18 AM   #2
I am not a licensed electrician, but have had some minor experience in this, having done it with my own electrical service.
You need to first determine your load of your circuit. I think you have to add up the total wattage of everything that will be on the panel (over estimating is better) then go here.
Amperage Calculator
http://www.csgnetwork.com/ohmslaw2.html
Once you have your Amperage, go here:
Voltage Drop Calculator
http://www.elec-toolbox.com/calculators/voltdrop.htm
This should give you a pretty good idea.
For instance, if you actually had a 200 AMP load at 240 volts/single phase, at 450 feet, your talking about 350 mcm cable if you go with copper. $$$$$ It might be cheaper to have the power company move the meter.
Randell Tarin is offline   Reply With Quote
Old 01-20-2008, 11:28 AM   #3
Spot on Randell.
I would definatly look at having the utility bring the service closer. They can run wire under different rules. It should be much cheeper.
Master Electrician
jwhite is offline   Reply With Quote
Old 01-20-2008, 12:49 PM   #4
Google "voltage drop calculator"
Heh heh...or just click on the link someone provided ^
220/221 is offline   Reply With Quote
Old 01-20-2008, 05:17 PM   #5
Rewards Points: 6,652
Or even better, keep a Pocket Ref. handy. I got mine from Ace Hardware, and has everything you can think of in it.
What's the ICC Electrical Code? Chuck Electrical 7 02-20-2013 10:19 AM
Can a homeowner perform electrical work in MA? dpd512 Electrical 77 04-11-2012 06:48 AM
Please Help - Weird electrical issue affecting home network sxpsxpsxp Electrical 23 02-03-2008 11:42 AM
OK to put electrical outlet into storage area under stairs? melanie_s Electrical 1 12-29-2007 04:09 PM
Code Question: Electrical and plumbing ELurie Electrical 2 08-22-2007 08:55 PM
