Electrical - Electrical - DIY Chatroom Home Improvement Forum
Old 09-22-2012, 06:05 PM   #1
williamdarrell's Avatar
Electrical
Presently have a three way switch in my hallway.
I would like to Change one toggle switch to dimmer so I can decrease lighting is this possible? Do I need a 4 way switch ?
williamdarrell is offline   Reply With Quote
Old 09-22-2012, 07:53 PM   #2
Licensed Electrician
jrclen's Avatar
Rewards Points: 514
You can purchase a three way dimmer switch to replace the three way switch you have.
John
jrclen is offline   Reply With Quote
The Following User Says Thank You to jrclen For This Useful Post:
williamdarrell (09-22-2012)
Old 09-22-2012, 11:13 PM   #3
" Euro " electrician
frenchelectrican's Avatar
There are quite few differnt style of three way dimmers on market but for now are you just replaceing with one three way dimmer and second switch as conventail three way switch ?
If so it pretty easy to do it however there is one more step you will have to pay attetion is common screw that typically darker colour screw than other two screws which typically bright brass.
The common will also marked as " C " so it will be either way and also I will advise you swap one conductor at time so it will not get this mixed up and final part make sure you have breaker off before you do this.
Merci,
Marc
Old 09-23-2012, 10:27 AM   #4
Ive put the three way switch in, now one of my switches turn the light off but the other two switches will not work in turning it on?
Did I get the wrong color screw?
Old 09-23-2012, 10:45 AM   #5
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Certainly sounds like it.
Pics work well for the pros to trouble shot your problem.
sublime2 is offline   Reply With Quote
The Following User Says Thank You to sublime2 For This Useful Post:
williamdarrell (09-23-2012)
Old 09-23-2012, 02:05 PM   #6
Rochsolid's Avatar
Other 2 switches? So you have 3 switches controlling this light?
Rochsolid is offline   Reply With Quote
Old 09-23-2012, 11:41 PM   #7
Maybe but what type of dimmer switch you have so we can able help ya on that.
Merci,
Marc
Proper way to ground a subpanel chieftaing Electrical 25 04-03-2011 11:22 AM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 07:46 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 10:48 AM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 03:42 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
