Old 09-20-2012, 07:47 PM   #1
Question
electrical
i have voltage on the casing of a parkinglot pole lihgt. i think it is a ground
issue. how do i resolve this problem.
khillelectric is offline   Reply With Quote
Old 09-20-2012, 07:53 PM   #2
electrical
You call a licensed electrician who knows what he is doing and can legally work in that situation.
ItsaSpider is offline   Reply With Quote
The Following 3 Users Say Thank You to ItsaSpider For This Useful Post:
frenchelectrican (09-21-2012), jrclen (09-20-2012), Speedy Petey (09-20-2012)
Old 09-20-2012, 08:40 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
electrical
+1
+1
+1
+1
+1
+1
Old 09-20-2012, 08:43 PM   #4
electrical
And kill the power to it until he shows up before it kills someone.
mpoulton (09-20-2012)
Old 09-20-2012, 09:00 PM   #5
Semi-Pro Electro-Geek
electrical
It's definitely a grounding/bonding issue, but it's also definitely another issue too. Turn off the power and call an electrician.
mpoulton is offline   Reply With Quote
Old 09-20-2012, 10:27 PM   #6
electrical
Ecerytime you work with wiring, be sure to turn off the circuit at the main breaker to ground or call professional electrician for the solution that you have wanted with your problem.
Last edited by Gary in WA; 09-21-2012 at 12:23 AM. Reason: Removed web ad that belongs below sign. line.
mcnakamura is offline   Reply With Quote
Old 09-20-2012, 10:28 PM   #7
electrical
Awesome, thanks for the advice (and the link).
Last edited by Gary in WA; 09-21-2012 at 12:24 AM. Reason: Removed quote link for ad.
Old 09-20-2012, 10:35 PM   #8
Master Electrician
electrical
There's been a few advertisers running around here lately. Anyone who needs to spam diy boards to drum up business has bigger problems than handing out advice everyone's already heard.
Sarcasm is my friend
I'm here to learn too, i do mostly commercial/industrial/new construction and this place is a great way to pick up tips on residential from some good electrical minds. Excuse the spelling, my phone has a mind of it's own.
andrew79 is offline   Reply With Quote
Old 09-20-2012, 10:37 PM   #9
liscenced electrician
electrical
What kind of voltage are swe talked about? 5 volts on the case or 277? Either way, your ground is lacking
jimmy21 is offline   Reply With Quote
Proper way to ground a subpanel chieftaing Electrical 25 04-03-2011 11:22 AM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 07:46 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 10:48 AM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 03:42 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
