Electrical - Electrical - DIY Chatroom Home Improvement Forum
Old 09-19-2012, 04:42 PM   #1
electrical
I have a chandelier with 4 wires brown,black and blue plus another with green and yellow. How do I wire this to the box with a black and white plus the bare ground wire. I am confused about thw 4 colored wires wgich one to connect to .
vivek is offline   Reply With Quote
Old 09-19-2012, 04:53 PM   #2
Julius793's Avatar
Are you from Europe or middle east? Those colors are not common in the states but the best would be take a tester and see which are hot,neutral, and switch leg. The way I've seen is brown being power, black as switch leg, and blue neutral, green - ground. But again each situation will vary.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 09-19-2012, 10:35 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,834
I agree with julius....most likely UK
Your green/yellow WILL be your earth ground....that connects to the bare copper wire.
Blue 'should' be neutral and will connect to the neutral white wire.
Black and brown....those should be hot....but the existance of two of them implies that you have two differnt ckts in the light....
Like Juluis said...get a tester (ohm meter) and ohm it out.
ddawg16 is online now   Reply With Quote
Proper way to ground a subpanel chieftaing Electrical 25 04-03-2011 10:22 AM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 06:46 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 09:48 AM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 02:42 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
