Electrical - Electrical - DIY Chatroom Home Improvement Forum
Old 08-27-2012, 04:06 PM   #1
Electrical
I have disconnected a light switch in renos and decided I was gonna use the connection to power a outlet.. Except now I can't get full power out of the outlet.. There is only one blk and one white wire. It's an old home but my thinking is maybe they're both hot and I req neutral now?
I have a switch now above it so if I need to run something else please help? Thank you
Leveille69 is offline   Reply With Quote
Old 08-27-2012, 04:38 PM   #2
Licensed electrician
Rewards Points: 1,630
With only a black and a white at a switch location you had a switch loop.Two wire switch loops do not have a neutral.
Old 08-27-2012, 04:44 PM   #3
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
When I read this reply all I can think is that the OP is not going to have ANY idea what you are saying.
Old 08-27-2012, 05:18 PM   #4
Rewards Points: 164
Not gunna work....
ryan50hrl is offline   Reply With Quote
Old 08-27-2012, 07:21 PM   #5
dmxtothemax's Avatar
Rewards Points: 5,366
You are correct Leveille !
You have two hots !
Known as a switch loop !
You have no neutral .
No go for recepticule .
dmxtothemax is offline   Reply With Quote
Old 08-28-2012, 01:32 PM   #6
joed's Avatar
Rewards Points: 12,918
If you are eliminating the switch then you also need to rewire the cable at the light fixture. As a switch loop there is no neutral connection and you have wired the receptacle in series with the old light fixture. You should find a black and white connected together at the old fixture and a black connected to the fixture. The old fixture will need to be removed and the black connected to the other blacks and the white connected to the other whites.
How are you going to control the fixture if you remove the switch?
Proper way to ground a subpanel chieftaing Electrical 25 04-03-2011 10:22 AM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 06:46 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 09:48 AM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 02:42 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
