Electrical - Electrical - DIY Chatroom Home Improvement Forum
Old 08-20-2012, 01:26 PM   #1
Electrical
I have a 20acr property in Lancaster, Ca. (County of LA). I am planning to build a 2500SF homes. To power it, SCE nearest utility pole was about 2500ft away from the house. I am thinking of installing 200A-120/240V, 1P, 3W, what would be the conduit and wire size required for this installations?
Tonyjr is offline   Reply With Quote
Old 08-20-2012, 01:29 PM   #2
Rewards Points: 14,306
Is the utility company not going to run that line under ground to your meter base for you?
Old 08-20-2012, 01:39 PM   #3
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
You might have to pay for it but the power company should specify wire size and type. I would suspect a pad mount transformer close to the new home?
Old 08-20-2012, 01:45 PM   #4
JOATMON
ddawg16's Avatar
Rewards Points: 2,124
Tony....that is prime property for solar.....especially with the heat you get up there.....
Old 08-20-2012, 01:57 PM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,268
No (practical) way can a 200 amp 120/240 volts service be run 2500 feet. Talk to the POCO about a transformer near your house.
Coastal South Carolina
The Following 2 Users Say Thank You to rjniles For This Useful Post:
mpoulton (08-20-2012), Speedy Petey (08-20-2012)
Old 08-20-2012, 02:30 PM   #6
Semi-Pro Electro-Geek
Rewards Points: 2,990
The power company will have to run primary (high voltage) much closer to the house. You can't run a 240V service that far and make it work practically.
mpoulton is offline   Reply With Quote
The Following User Says Thank You to mpoulton For This Useful Post:
Old 08-20-2012, 02:52 PM   #7
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
If you could, you sure would hate to see the size wire and conduit needed!
jbfan is online now   Reply With Quote
Old 08-20-2012, 02:58 PM   #8
A "Handy Husband"
rjniles's Avatar
Copper 2000 mmca, I don't even know what that size is but that what an on line calculator calls for. You need the POCo to get involved.
The calculator could not determine a size for aluminum.
Old 08-20-2012, 04:29 PM   #9
Oso954's Avatar
Rewards Points: 1,654
You need to contact SCE immediately and talk to them.
Their service line extensions are under Rule 16, distribution line extensions are Rule 15. They will tell you which rule (or both) that will apply to your situation.
Their allowance for a new service installation was $2506 per meter as of 2011. You will be responsible for all costs above that, which are likely to be quite substantial.
If you want to read the Rules,
http://www.sce.com/NR/sc3/tm2/pdf/Rule15.pdf
http://www.sce.com/NR/sc3/tm2/pdf/Rule16.pdf
Oso954 is offline   Reply With Quote
Old 08-20-2012, 07:34 PM   #10
JOATMON
ddawg16's Avatar
Tony....I have a few friends over at SCE....let me know if you hit a roadblock and nees some help....
Proper way to ground a subpanel chieftaing Electrical 25 04-03-2011 10:22 AM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 06:46 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 09:48 AM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 02:42 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
