Electrical - Electrical - DIY Chatroom Home Improvement Forum
Old 07-28-2012, 03:50 PM   #1
Lightbulb
electrical
i am trying to replace a breaker panel in a rv park , the breaker in the panel is a 30 amp and its wired to a 30 amp rv receptacle, can i replace the 30 amp receptacle with a new 30 amp receptacle and run it off of a 50 amp breaker instead of useing a 30 amp breaker
jayg0328 is offline   Reply With Quote
Old 07-28-2012, 04:36 PM   #2
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
No. 30a recept 30a breaker. Or replace conductors with 50a conductors.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
Old 07-28-2012, 05:12 PM   #3
Msradell's Avatar
Rewards Points: 210
Short answer NO! Long answer certainly not! The receptacle is only rated for 30 amps, the 50 amp breaker would allow excessive power to reach it in this would be a hazard and certainly against code!
Msradell is offline   Reply With Quote
Proper way to ground a subpanel chieftaing Electrical 25 04-03-2011 10:22 AM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 06:46 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 09:48 AM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 02:42 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
