Electrical. - Electrical - DIY Chatroom Home Improvement Forum
Old 07-11-2012, 02:02 PM   #1
Electrical.
I have 3 outdoor lights thats on a timer.i will like to stop using the timer and install motion detection lights instead how do i do that.
kwessan is offline   Reply With Quote
Old 07-11-2012, 02:07 PM   #2
Hi, where is the timer and how is it mounted?
CopperClad is offline   Reply With Quote
Old 07-11-2012, 02:12 PM   #3
The timer is located in the garage and is mounted on the wall with on and off switch.
Old 07-11-2012, 02:19 PM   #4
So it is next to an on and off switch? or you can turn the timer on and off with the switch?
Old 07-11-2012, 02:27 PM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I get the distinct feeling this person shouldn't attempt their own electrical work.
Old 07-11-2012, 02:29 PM   #6
Hi copperclad,
The on and off switch comes with the timer in other words i can manually shut it off.
Old 07-11-2012, 02:32 PM   #7
The timer has a manual on/off lever.Hope this helps.
Old 07-11-2012, 02:34 PM   #8
okay. If you have an on/off switch to the timer... Then all you need to do is take down the old lights and put up the motion detector lights and leave the switch on. (of course with the breaker off while you're doing this)
Old 07-11-2012, 02:35 PM   #9
Thats funny.
Old 07-11-2012, 02:46 PM   #10
Thanks very much i will try it out.
Old 07-11-2012, 02:48 PM   #11
I wouldn't take any advice from me. I'm no electrician. I just like to say what I think and then the real electricians correct me.
Proper way to ground a subpanel chieftaing Electrical 25 04-03-2011 11:22 AM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 07:46 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 10:48 AM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 03:42 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
