Old 04-14-2012, 05:46 PM   #1
Electrical
twin lamp sockets w/3 way switch.(for florescent bulbs),
Can I buy a lamp fixture w/2 bulb sockets that work on a 3-way switch which on the 1st click lights one bulb, on the 2nd click lights only the other bulb, on the 3rd click lights both bulbs, on the 4th click turns off the lamp?
Jim King is offline   Reply With Quote
Old 04-14-2012, 06:59 PM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Electrical
Well, I have no idea what kind of fixture you're talking about this can be done. You may find something that is setup this way, or you can also add a 3-way switch to almost any fixture.
Speedy Petey is online now   Reply With Quote
Old 04-14-2012, 10:31 PM   #3
I=E/R
a7ecorsair's Avatar
Electrical
I think you are looking for something like this:
http://www.antiquelampsupply.com/pro...-rotary-switch
a7ecorsair is offline   Reply With Quote
Old 04-15-2012, 04:51 AM   #4
Tool Geek
PaliBob's Avatar
Electrical
It is possible to have a lamp fixture wired like that but I have not seen one. The logic of a classic three way switch with an incandescent 3-way bulb is:
  1. Lower Filament
  2. Higher Filament
  3. Both Filaments
  4. Neither Filament
& Stay Safe
.....Bob Lavery
Old 04-15-2012, 08:06 AM   #5
Pure Genius
Electrical
Typically it would be the ballast that would control this
Dierte is offline   Reply With Quote
Old 04-15-2012, 04:59 PM   #6
Electrical
The reason for this is to use the new swirly type florescent bulbs (very inexpensive) instead of the 3-way swirly type florescent bulbs (very expensive). I stayed in a Best Western Motel in PA which used this type of fixture in their lamps. Very smart.
Old 04-15-2012, 05:04 PM   #7
Pure Genius
Electrical
A 3 way cfl costs between 8-12 dollars. Not very expensive imo
Proper way to ground a subpanel chieftaing Electrical 25 04-03-2011 11:22 AM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 07:46 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 10:48 AM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 03:42 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
