Electrical - Electrical - DIY Chatroom Home Improvement Forum
Old 03-27-2012, 08:40 AM   #1
electrical
can a 2 pronged receptical be replaced with a3 pronged receptical
ephraim is offline   Reply With Quote
Old 03-27-2012, 09:10 AM   #2
Rewards Points: 6,652
Is there a ground wire in the box?
Old 03-27-2012, 09:48 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,192
This is becoming one of the more often asked questions (along with sub-panels) on this forum. Using the search function will give you a lot of info.
If you have a valid ground, yes.
If the circuit is GFCI protected, yes
Otherwise , no
Coastal South Carolina
The Following 2 Users Say Thank You to rjniles For This Useful Post:
Jim Port (03-27-2012), zappa (03-28-2012)
Old 03-27-2012, 09:45 PM   #4
"So I Re-Wired It"
MisterZ's Avatar
to help the OP understand a bit better...
the third prong on a 3-prong recept is the ground.
if the recepticle box is "properly grounded" or the existing wire has the
third bare copper ground wire, you are all set to go. (the latter is unlikely)
however if there is no ground, simply replacing with a 3-prong would be pointless.
you could change it anyway, but this is NOT advised.
either find a way to add a ground, or update the wire.
keep in mind this outlet may pigtail off other outlets/lights
good luck, be safe, and dont short-cut
MisterZ is offline   Reply With Quote
Old 03-28-2012, 12:22 AM   #5
Rewards Points: 512
If no ground wire is available, you can put a GFCI receptacle in. It shuold be labeled "no ground".
Proper way to ground a subpanel chieftaing Electrical 25 04-03-2011 10:22 AM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 06:46 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 09:48 AM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 02:42 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
