Electrical - Electrical - DIY Chatroom Home Improvement Forum
Old 02-24-2012, 03:04 PM   #1
electrical
how many outlets & lights are allowed in one breaker
ikit is offline   Reply With Quote
Old 02-24-2012, 04:52 PM   #2
Julius793's Avatar
As many as you wish, use common sense.
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
The Following 2 Users Say Thank You to Julius793 For This Useful Post:
gregzoll (02-24-2012), plummen (02-25-2012)
Old 02-24-2012, 05:04 PM   #3
Licensed electrician
Rewards Points: 1,020
Are you in the US or Canada? It makes a difference. Is this residential?
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
plummen (02-25-2012), Speedy Petey (02-24-2012)
Old 02-24-2012, 08:04 PM   #4
joed's Avatar
Rewards Points: 11,556
In Canada the limit is 12 outlets per circuit. If the circuit is lighting 15 amps is your limit.
Old 02-24-2012, 08:29 PM   #5
Marine Electrician (LO)
I believe according to the NEC (US electric code), the calculation is 1.5amps per load (basic light or receptacle) up to 80% of the rating of the circuit breaker.
So if you have a 20 amp circuit breaker, 80% is 16 amps, which allows you up to 11 receptacles or lights.
30Five is offline   Reply With Quote
Old 02-24-2012, 09:26 PM   #6
There is no limit under the NEC for residential applications. The 80% loading would only come into play if the load was continuous for 3 hours or more.
Hardway (02-24-2012), plummen (02-25-2012)
Old 02-24-2012, 10:56 PM   #7
Rewards Points: 6,652
There is no 80% for lighting load, or receptacles. The 80% only comes into factor for certain loads. Now, the catch to that one is, when you figure total allowance on a circuit, you can safely load it in design up to 80% of the ocpd, before you start taking away from headroom, due to some people tend to leave lighting on in a room for long terms, or run a window a/c, computer, tv, etc. for more than a couple of min's or hours. If it is a well pump, or vent fan, yes you automatically have to figure in 80% of the load on the circuit, otherwise, that rule flies out the window for the majority of the circuits.
Old 02-24-2012, 11:29 PM   #8
Ah you're right. I looked back in my 2011 NEC. My bad.
Proper way to ground a subpanel chieftaing Electrical 25 04-03-2011 11:22 AM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 07:46 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 10:48 AM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 03:42 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
