Old 02-09-2012, 10:03 AM   #1
Question
Electrical
I've just installed a backsplash on the wall above the kitchen counter. The electrical switch boxes and outlets are now deeper in the wall. How do you go about bringing them forward so that the wall plates and electrical boxes behind them are solid and secure once again. I've read about box extenders but is this necessary or appropriate just for adding a backsplash? Thanks, Tom
Thomas Skene is offline   Reply With Quote
Old 02-09-2012, 10:09 AM   #2
Electrical
A box extender may bring it out to far.
Lowes and HD have packs of plastic spacers that just slip over the screws on the backside of the outlets in the electrical dept..
Your also going to need longer screws.
Old 02-09-2012, 10:11 AM   #3
Julius793's Avatar
Electrical
How big is the space?
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
The Following User Says Thank You to Julius793 For This Useful Post:
plummen (02-09-2012)
Old 02-09-2012, 10:15 AM   #4
Licensed electrician
Electrical
The face of the box will need to be extended so it is flush if the surface is combustible, up to 1/4" setback if non-combustible.
With that said, the receptacles will be springy if not supported correctly.
Old 02-09-2012, 11:56 AM   #5
Love for Construction
<*(((><'s Avatar
Electrical
I would use the blue thick box extender for more support of the outlet, if you can get the right thickness.
-luke-
<*(((>< is offline   Reply With Quote
Tags
backsplash, electric, outlets
Proper way to ground a subpanel chieftaing Electrical 25 04-03-2011 11:22 AM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 07:46 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 10:48 AM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 03:42 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
