Electrical - Electrical - DIY Chatroom Home Improvement Forum
Old 01-28-2012, 07:43 PM   #1
electrical
Can someone please help me? I had one of the plugs in my outlet not working so i thought i would replace the outlet when i did it got arcked so i tried another new outlet and this is the outlet on my deck outside now none of the outlets will work in my kitchen
pkmoon7 is offline   Reply With Quote
Old 01-28-2012, 07:48 PM   #2
Licensed electrician
Rewards Points: 1,864
Sounds like you tripped a GFI.
The kitchen receptacle should not have be feeding the outside receptacle.
Old 01-28-2012, 07:48 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 648
Check for a tripped gfci.
Old 01-28-2012, 07:50 PM   #4
Rewards Points: 582
when it sparked you triped the breaker or gfi..need to be reset
Old 01-29-2012, 06:50 AM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,990
Did you do it live?
Do you even have a tester?
Was the tab in between the gold screws broken off?
Are you in Canada?
Proper way to ground a subpanel chieftaing Electrical 25 04-03-2011 10:22 AM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 06:46 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 09:48 AM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 02:42 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
