Electrical - Electrical - DIY Chatroom Home Improvement Forum
Old 01-24-2012, 06:36 PM   #1
Electrical
I have a drop down service with 200A cut-off box with 2 200A fuses. How do I hook this up to my 100A breaker box in my mobile home?
sherisser is offline   Reply With Quote
Old 01-24-2012, 06:43 PM   #2
MarginallyQualified
Rewards Points: 2,464
Carefully.
First step is to *extend* the power from that disconnect to the MH.
Aerial? OK Direct Burial? Sure Conduit with THWN? OK
What is most common where you are?
Originally Posted by WireMaker
All of our THWN electrical wire is dual rated with THHN wire because they're manufactured very similar with almost no cost difference. It's the most standard type of electrical wire on the market because it's used as a single condutor electrical wire and also used in most electrical cables as well.
Old 01-24-2012, 07:18 PM   #3
jproffer's Avatar
Rewards Points: 716
Originally Posted by TarheelTerp View Post
Carefully.
Aerial? OK Direct Burial? Sure Conduit with THHN? OK
Only thing I'd argue with is the THHN. If it's buried, it has to be THWN.
jproffer is offline   Reply With Quote
Old 01-24-2012, 08:05 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,990
While this is an often mentioned correction, it must be said that you'd be hard pressed to find new THHN wire that is not dual rated THWN.
The Following 3 Users Say Thank You to Speedy Petey For This Useful Post:
frenchelectrican (01-24-2012), jbfan (01-24-2012), SD515 (01-24-2012)
Old 01-24-2012, 08:07 PM   #5
**Topic of your question goes here**
Yes, this is the electrical section and this is an electrical question.
Step one: Call an electrician.
Step two: Receive quote from said electrician.
Step three: Award job to electrician.
Step four: Enjoy your newly electrified mobile home.
Old 01-24-2012, 08:48 PM   #6
jproffer's Avatar
Rewards Points: 716
Fair enough.
Just pointing it out...
Proper way to ground a subpanel chieftaing Electrical 25 04-03-2011 10:22 AM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 06:46 AM
For stacked dryer/washer - where to locate electrical outlets and water supply lines Cliffhanger Electrical 3 09-05-2010 09:48 AM
Electrical Panel Upgrade & Main Water Shut Off DIYerIT Electrical 2 09-02-2010 02:42 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
