ELECTRICAL - Electrical - DIY Chatroom Home Improvement Forum
Old 06-22-2011, 09:13 AM   #1
eLECTRICAL
What is special about a T Slot recepticle
kinggulliver is offline   Reply With Quote
Old 06-22-2011, 09:19 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 648
It is a 20 amp receptacle.
Where is it located?
jbfan is online now   Reply With Quote
Old 06-22-2011, 09:25 AM   #3
Electrical
I understand it is a 20A circuit and required in the kitchen, so does one need a special plug or can a standard 15A plug be used. If not, then does one have to change all of ones electrical plugs to suit?
Old 06-22-2011, 09:30 AM   #4
jbfan's Avatar
Rewards Points: 648
Unless you are in Canada, the 20 amp receptacles are not required in the us.
It should be a combo, that allows a 15 amp plug to fit as well as a 20 amp plug.
Old 06-22-2011, 09:48 AM   #5
Yep, I am in Canada and thanks. As long as I can plug in a standard kettle or toaster I can use all T types in the kitchen. I was hoping I could find out on line rather than run down to the locat hardware store and actually try the regular plug in a 'T' socket. Thanks again.
Old 06-22-2011, 04:44 PM   #6
Electrician
Rewards Points: 802
Your good to go with the plugs you have on your applicances.
If you happen to find a appliance with a 20A t-slot, please let me know and I will start to understand a little more why we have to put 20A t-slots in a kitchen when I have never seen a household appliance with a 20A cord end.
darren is offline   Reply With Quote
DIY Electrical work in New Jersey electures Electrical 42 12-19-2012 03:19 PM
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 06:46 AM
Changing from Electrical Cook Top to Electrical Range EkS Electrical 24 06-22-2010 10:43 AM
How to install new electrical box without attic access gilmores33 Electrical 10 02-14-2010 07:46 PM
Electrical box replace,addiitions, city permits and looking for an electrician ramchy Electrical 3 08-02-2009 11:12 AM
