Electric Wiring For Fluorescent Lamp - Electrical - DIY Chatroom Home Improvement Forum
Old 03-24-2008, 11:13 AM   #1
Post
electric wiring for fluorescent lamp
Hi
I've searched the forum and the web and I can't find an answer for my situation. Here's what's going on.
I have two instant start fluorescent lamp (two 4 feet tubes each lamp). When you get them out of the box each lamp comes with a 2' cable ending in a 3 stud plug. Need less to say 2 feet cable is not long enough.
So I cut the plugs, wire white with white , black with black and green with green of the two lamps. Then I run a cable and wire it in the same color scheme with the lamps. The new cable ends in a plug that I just connect to the wall outlet. The lamps work for one or two weeks.
But eventually 1 of the lamps dies. The first time I knew getting a ballast was not cost effective so I got a new lamp. I installed and re-wired. Worked for a week the other lamp died. Someone told me I'm getting a bad batch of lamps. I have now 3 dead lamps. However I think is a wiring issue.
Should I try to run them in serial instead of parrallel like now ?
how the wiring go ?
lamp1 white to lamp2 black
lamp1 black to outlet black
lamp2 white to outlet white
all greens together
Or could it be the type of lamp that isn't made to be shared in the same circuit ?
I refuse to lose this fight help
toronbolo is offline   Reply With Quote
Old 03-24-2008, 11:23 AM   #2
Rewards Points: 58
When you purchase a lamp with cord that you do not want to use, I would remove the cord. Not cut the cord and extend the cord. Remove the cord from the inside of the lamps. Leave all the covers off. Jump from lamp to lamp with romex or equivalent. Cords are not permitted in permanent installations. Then take the last cable and tie it into a switch. If you must, you can put a plug on that end.
If the lights work for one week, two week it is not in your wiring. It is either the ballasts or tubes. I get bad tubes in brand new boxes all the time. I just collect them until I go back to the supply house and return them.
Just because something is new, does not mean it is bad.
Have you checked the voltage feeding the lamps? If not, check it. If it high, then the ballast output will also be high and possibly burning out the tubes prematurely.
Old 03-24-2008, 12:04 PM   #3
" Euro " electrician
frenchelectrican's Avatar
Did you check the bulb wattage ?? most instat start ballast will label to tell you what type of bulb to use on that one like example F32T-8 or F40T12 or F34T12 ?? because some of them will not work with the ballast and just check it out as well to make sure they match up.
Merci, Marc
Old 03-24-2008, 01:16 PM   #4
joed's Avatar
Rewards Points: 11,560
Your wiring was correct. Parallel is the proper way. Sounds like cheap lamps. Too bad you cut the cords. I would have returned them under warranty.
Electric receptacle in lamp post and flood light not working th31 Electrical 7 12-13-2007 08:46 AM
Wiring electric heater in bathroom PatSea Electrical 5 01-06-2007 10:40 PM
Electric Range Wiring manhattan42 Electrical 11 07-05-2006 06:03 PM
Wiring from electric motor subman Electrical 1 06-24-2005 11:37 PM
Wiring from electric motor Submarineman Electrical 1 06-17-2005 01:50 AM
