Electric Wire Question - Electrical - DIY Chatroom Home Improvement Forum
Old 05-04-2010, 10:05 AM   #1
Electric Wire question
I have a question. I was hoping you guys could help me with.
I need to run a water pump in my pond. The pond is located almost 800' from my panel in the house. I was going to bury the wire hoping to do a direct burial. The pump is somewhat small it uses 1.3 amps 150 watts.
How heavy of a wire would I have to use for this length to safly run the water pump.
Thanks in advance for any suggestions.
Mike
Wild Thyme Woodworking
Mr Big is offline   Reply With Quote
Old 05-04-2010, 10:18 AM   #2
Electrician
Rewards Points: 794
With my calculations I end up with #10 for a 3% voltage drop.
darren is offline   Reply With Quote
The Following User Says Thank You to darren For This Useful Post:
Mr Big (05-04-2010)
Old 05-04-2010, 10:41 AM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 490
You may want to consider solar after you price the wire!
Old 05-04-2010, 10:48 AM   #4
I wish I new more about solar. The problem is the pump needs to run 24 hours a day and even through the winter. Do you know what I would need to make up a solar pacage that could do this? I am willing to clean off the panels when ever I need to ie after it snows. The area does have direct view to the south.
The wire would have to be purched in 1000' roll and it is almost $1000 bucks!!
Old 05-04-2010, 10:53 AM   #5
jbfan's Avatar
Rewards Points: 490
I'm thinking solar charger, deep cycle battery and an inverter.
The charger is the one you may have trouble designing.
It has to be larger than a trickle charger.
Check Bass Pro shops for some chargers.
Others may have better ideas.
Old 05-04-2010, 11:49 AM   #6
1.3 A, 5% drop @ 120v gives 6v/1.3A = 4.6 ohms for the cable resistance.
With 1600' conductor length, 4.6 ohms/1600' = 2.9 milliohms per foot. I get #14, copper.
Old 05-04-2010, 12:31 PM   #7
Electrician
Rewards Points: 794
Are you allowed 5% voltage drop on a branch circuit according the NEC.
The CEC only allows us a 3% voltage drop.
Old 05-04-2010, 01:49 PM   #8
Dunno'; for us in the US it might be 5% total from the load center to the farthest outlet.
I know extension cords seem to go with a 5% max drop so apparently most equipment can tolerate this much resistance in the supply line. And this is on top of the 120v +/-5% or +/- 10% available at the outlet.
He could also use 150w step-up and a step-down transformers at the ends but thicker cable may be cheaper. If you're happy with #14 then using 240v over the distance would need about 17 AWG copper.
Or get a 240v, 0.7A pump.
8 hrs sun/16 hrs without, and we need 24(150w) = 3600 w-h and we have <8 hours to get it, so 3600/8 = >450w solar panel = >3 sq. meters.
Worst case cost is one kilobuck. We can beat that price!
Old 05-04-2010, 02:01 PM   #9
Electrician
Rewards Points: 794
I think the OP should look into getting a similar size motor but make it 240V. This would greatly help his voltage drop issues.
2 Wire Thermostat question vtec69 Electrical 19 10-19-2009 05:14 PM
Thermostat Wire Question TJ_in_IL HVAC 5 10-16-2009 05:57 PM
Newbie's first question, pinched wire drtbk4ever Electrical 3 12-30-2008 11:20 AM
Dumb Neutral wire question, just curious. helpless handyman Electrical 14 12-28-2008 12:48 PM
3 wire to 4 wire question macmouse Electrical 24 05-01-2008 05:34 AM
