Electric And Water Lines In Same Trench - Electrical - DIY Chatroom Home Improvement Forum
Old 01-08-2011, 10:57 PM   #1
Electric and Water lines in same trench
I am running power and water lines to new shop 70 feet from house.
I have dug a trech 2 feet deep, for water I am using 3/4" pvc and for electric I am using 3/4 grey pvc #40 using 12/2 with ground.
My question, can I run both lines in same trench? If so - can they both lay at same depth or should I run electric above water line and how many inches above?
LD
lond is offline   Reply With Quote
Old 01-08-2011, 11:08 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
Are you using uf cable in the conduit?
Old 01-08-2011, 11:16 PM   #3
I am not using UF wiring, but am using the grey conduit
Old 01-08-2011, 11:16 PM   #4
Where do you live? Water lines must be below the frost line.
In my area this is 4 feet.
Old 01-08-2011, 11:18 PM   #5
Originally Posted by lond View Post
I am not using UF wiring.
UF wire can be run underground
Reg 12-2 can't be run underground
You need THWN, individual wires
Old 01-08-2011, 11:20 PM   #6
jbfan's Avatar
Rewards Points: 138
Like dave said, nm-b cannot be installed in a wet location.
Here 2 feet is way below the frost line.
Old 01-08-2011, 11:25 PM   #7
I live in Tucson Arizona and we get less than a foot of rain a year. As for the frost line.... it does get cold and maybe a frequent freeze once or twice a year of course at night.
Old 01-08-2011, 11:28 PM   #8
being not much rain and no freezing, this is why I was thinking of laying the water line at 2 ft and then lay the electric line at 16" ..... thoughts
Old 01-08-2011, 11:31 PM   #9
jbfan's Avatar
Rewards Points: 138
They can lay side by side, but you still have the issue of 12/2 non uf in a wet location that is against code.
The Following User Says Thank You to jbfan For This Useful Post:
lond (01-08-2011)
Old 01-08-2011, 11:36 PM   #10
Thank you and I will reconsider changing to UF wiring
Old 01-09-2011, 12:44 AM   #11
liscenced electrician
Rewards Points: 538
side by side is perfectly fine, but as others have said, either individual conductors or UF.
What is the pvc water line for? You know pvc isnt drinkable, right?
jimmy21 is offline   Reply With Quote
Old 01-09-2011, 02:31 AM   #12
Scared Electrician
Saturday Cowboy's Avatar
Why aren't you running at least 60A to you shop? Conduit has to be buried to 18", direct burial wire to 24". I recommend 1" pvc for future expansion. As mentioned above romex can't be outside.
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 01-09-2011, 06:48 AM   #13
UF wire
You stated (I will reconsider changing to UF wiring).
Will you re-consider, re-pulling with UF, or digging everything back up to do it correctly when it fails??
Bob
Hourglass52 is offline   Reply With Quote
should I switch from natural gas to electric water heater supermaxhd Plumbing 24 11-28-2010 01:11 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
Electric Water Heater Issues - Water Too Hot after tstat replacement and Sulfur Smell marman4880 Plumbing 4 08-05-2010 05:25 PM
Electric Water Heater GTSRider Plumbing 31 12-07-2008 12:30 PM
Electric tankless hot water heater former33t Plumbing 2 02-28-2008 12:40 PM
