Electric Water Heater Rewire - Electrical - DIY Chatroom Home Improvement Forum
Old 10-13-2010, 08:41 AM   #1
electric water heater rewire
In the rewiring of 50gal water heater replacing the 10-2 copper with 10-3 copper wire. the water heater had only two connecting wires; black and red. The white wire from the original 10-2 going to the heater was attached to the grounding screw noted on the top of the heater. In replacing with the 10-3 should I again attach the wht. neutral wire to the grounding screw and run the bare ground to a cold water pipe?
dghowery is offline   Reply With Quote
Old 10-13-2010, 08:48 AM   #2
Licensed electrician
Rewards Points: 1,766
A two conductor cable + ground is all that is needed for a water heater. You do not need a neutral, just two hots. The white will get re-identified as a hot with black or red tape or magic marker.
I do not know how yours was functioning with a hot connected to ground.
Do not make any connections between a water line and the wiring for grounding.
Old 10-13-2010, 09:07 AM   #3
so the wiring for the electric water heater is red to red, black to black and white to ?
Old 10-13-2010, 09:15 AM   #4
There is no white used on a straight 240 volt unit. The white in the cable is used as a hot conductor and is re-marked to show its new usage.
Old 10-13-2010, 11:11 AM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 546
Cap off the white, and connect the bare to the ground screw on the water heater.
jbfan is online now   Reply With Quote
Old 10-13-2010, 12:18 PM   #6
Just call me Andrew
Rewards Points: 1,020
Why are you replacing 10-2 with 10-3?
Andrew
secutanudu is offline   Reply With Quote
Old 10-13-2010, 05:06 PM   #7
Electrician
Rewards Points: 802
black to black
white to red
bare to the ground
Mark the white red with a marker or electrical tape.
Just because it is white does not mean it has to be a neutral.
darren is offline   Reply With Quote
New Electric Water Heater Install RustyRealtor Plumbing 11 04-17-2009 06:38 AM
Multiple hot water heater issues a-6intruder Plumbing 8 01-16-2009 05:58 PM
Water heater drain mechanism (10 year old) guptaalok Plumbing 1 01-02-2009 05:40 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
