-   -   electric water heater rewire (http://www.diychatroom.com/f18/electric-water-heater-rewire-83801/)
dghowery 10-13-2010 08:41 AM
In the rewiring of 50gal water heater replacing the 10-2 copper with 10-3 copper wire. the water heater had only two connecting wires; black and red. The white wire from the original 10-2 going to the heater was attached to the grounding screw noted on the top of the heater. In replacing with the 10-3 should I again attach the wht. neutral wire to the grounding screw and run the bare ground to a cold water pipe?
Jim Port 10-13-2010 08:48 AM
A two conductor cable + ground is all that is needed for a water heater. You do not need a neutral, just two hots. The white will get re-identified as a hot with black or red tape or magic marker.
I do not know how yours was functioning with a hot connected to ground.
Do not make any connections between a water line and the wiring for grounding.
dghowery 10-13-2010 09:07 AM
so the wiring for the electric water heater is red to red, black to black and white to ?
Jim Port 10-13-2010 09:15 AM
There is no white used on a straight 240 volt unit. The white in the cable is used as a hot conductor and is re-marked to show its new usage.
jbfan 10-13-2010 11:11 AM
Cap off the white, and connect the bare to the ground screw on the water heater.
secutanudu 10-13-2010 12:18 PM
Why are you replacing 10-2 with 10-3?
darren 10-13-2010 05:06 PM
black to black
white to red
bare to the ground
Mark the white red with a marker or electrical tape.
Just because it is white does not mean it has to be a neutral.
