Electric Water Heater - Electrical - DIY Chatroom Home Improvement Forum
Old 01-26-2009, 11:35 AM   #1
Electric water heater
I bought a half build home with wiring already run. It has 10-2 wire running to the hot water tank location. My question is do I need 10-3 run to there or is 10-2 O.K? Can I make the white wire my red wire? Or do I have to have a neutral?
Thanks in advance
Sparkywannab is offline   Reply With Quote
Old 01-26-2009, 12:17 PM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
10/2 is fine. Just "re identify" the white with a color like black, red, etc. Water heater's don't need a neutral.
wirenut1110 is offline   Reply With Quote
Old 01-26-2009, 12:18 PM   #3
Electrician
SD515's Avatar
Rewards Points: 504
Usually checking the manufacturers instructions and your local authority will answer that. I've heard of some (actually, only once...I think the inspector was 'off base'...where was I suppose to attach the neutral wire??) jurisdictions requiring 10/3, but most dont. Tape/paint the white wire black at boh ends and you should be all set.
Kyle
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
Replacing a Water Heater with Electric One 2031pratt Plumbing 3 12-26-2008 09:17 AM
Electric Water Heater GTSRider Plumbing 31 12-07-2008 11:30 AM
Pool timer on an electric water heater...Yes or no? Gusaroo Plumbing 2 09-01-2008 08:13 AM
