Electric Water Heater - Electrical - DIY Chatroom Home Improvement Forum
Old 11-13-2011, 12:41 PM   #1
Can I connect a 240/208-50Gal.-Electric Hot Water Heater to exsisting wiring (once used for a dual electric oven) 2 joined 30amp breakers (60amp total) or is this overkill and/or dangerous?
UAUSA is offline   Reply With Quote
Old 11-13-2011, 12:50 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 138
You do not have 60 amps, you have a 2 pole 30 amp breaker, and that is fine for the water heater.
Old 11-13-2011, 01:49 PM   #3
A 4500W element at 240V pulls 19A and presents a 13 ohm load. You'll need this info if you ever have to troubleshoot this setup. And with 240V there is some arc-flash danger.
Old 11-13-2011, 02:05 PM   #4
liscenced electrician
Rewards Points: 538
Thats one really annoys me. I don't know how many times i explain it to my father in law, he still doesn't get it. Explain it simply, explain it in depth, doesn't matter.
you have 30 amps at 240v. This is not the same as 60amps of 120v or 60 amps of 240. A 30 amp breaker is a 30 amp breaker, no matter how many phases
jimmy21 is offline   Reply With Quote
Old 11-13-2011, 02:18 PM   #5
I=E/R
a7ecorsair's Avatar
And there is that phase term. It is single phase at 240 and single phase at 120
As far as the 240 volt circuit, tell him the breakers are in series. You have 30 amps through one and it is the same 30 amps that flows through the other.
a7ecorsair is offline   Reply With Quote
Old 11-13-2011, 02:28 PM   #6
Rewards Points: 538
i realize that, but i think everyone still uses terms like "phase a and phase b" or "phase to phase." Even though its still single phase. Also, my statement of "A 30 amp breaker is a 30 amp breaker, no matter how many phase" isn't just residential. Still applies with 480v 3 phase breakers
Old 11-13-2011, 02:28 PM   #7
This means that, over a long time, you have accumulated knowledge in an area that most people are ignorant of, and you don't know how much knowledge you have accumulated.
It has become second nature to you.
After high school you may not assume that others know what you know, or even that they are capable of understanding what you tell them.
I had to work in a hardware store for a while and I was amazed that many people of any age did not understand how the current can flow from a battery, through a wire and light a little bulb.
Worse, some people who work with electricity have the most bizarre notions of what is really happening. This, because it seems to fit what they are observing.
Maybe it's because the flow of current is invisible.
Dunno'.
Solar "Batch" Hot Water Heater, Help Please Ralph III Green Home Improvement 1 10-29-2011 10:12 PM
Pressure drop across water heater, low hot water flow HVAC_NW Plumbing 2 01-17-2011 11:43 PM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 01:01 AM
electric water heater rewire dghowery Electrical 6 10-13-2010 06:06 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
