Electric Tracing On Roof? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-13-2012, 06:03 PM   #1
Electric tracing on roof?
I put in a gutter guard system this spring( has 1/8th inch hole pattern) for my troughs... Was wondering if I now should electric heat trace the gutters and roof line so that ice and snow don't form overtop. Any thoughts or advice?
stoked91 is offline   Reply With Quote
Old 11-13-2012, 06:20 PM   #2
You don't say where you are. If you have proper soffitt/ridge vents installed, melting from underneath should not be an issue. Melting from above by the sun is beyond our control. We generally have mild winters, but I have not had an ice dam issue since I installed soffitt/ridge vents.
Old 11-13-2012, 08:07 PM   #3
I live up in London Ontario... We get quite the winters
Old 11-13-2012, 08:28 PM   #4
Rewards Points: 12,818
Need two differant ones. One goes on the roof the other goes inside the gutters.
help! strange horizontal bubbles on new roof dfwnewroof Roofing/Siding 49 11-17-2012 07:46 AM
rubber roof over tar & thoughts on quote wfmrules3 Roofing/Siding 13 10-16-2011 10:00 PM
Flat roof and insulation quandry paredown Roofing/Siding 2 08-21-2010 12:50 AM
Strange Winter Roof Leak Dragon Roofing/Siding 16 10-09-2009 07:06 PM
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 10:44 AM
