Old 03-30-2011, 11:47 AM   #1
Smile
Electric Time Switch
I have a model 59396 Woods Multi-Volt Switch, the Clock is 120V. Switch is 240V. the terminals are Two for the timer. one NC One NO and a COM. I don't know what NO is. Can I run the 120V clock off one leg of the 240 and a the COM. or must I run a seperate line. Where do I hook the 2 lines going to the heater.
David Cosner is offline   Reply With Quote
Old 03-30-2011, 12:09 PM   #2
NO and NC usually refer to normally open and normally closed. Don't know how it is used in this application. It is often used for relay wiring.
teamo is offline   Reply With Quote
Old 03-30-2011, 12:15 PM   #3
nap
You talking to me?
nap's Avatar
NO= normally open
NC= normally closed
COM= common (to the associated NO and NC contacts)
you need to run a 120 volt circuit for the clock and attach the hot to terminal 1 and the neutral to terminal 2.
then, for your 240 volt circuit,
run one of the circuit conductors to the COM terminal. The other circuit conductor will pass straight through without any connections to the timer. Then, along with that passed through circuit conductor, attach a wire to the NO terminal and take both of them to the heater or whatever you are operating.
there is a diagram in your owners manual.
B&S Generator with Connecticut Electric Xfer Switch Rick5150 Electrical 19 01-20-2011 11:14 PM
Changing 220V to 110V (hardwired) for an electric to gas cooktop switch. charleyhart Electrical 14 01-15-2011 02:12 AM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
3-way light with a twist Jeepsail Electrical 14 05-18-2010 02:24 AM
3-way switch help amit Electrical 17 02-15-2010 04:17 PM
