Electric Stove Wiring - Electrical - DIY Chatroom Home Improvement Forum
Old 07-11-2009, 08:12 PM   #1
Today I was putting some OSB in the attic and I drilled a deck screw into the wire foir the electic range. There was an spark but the breaker did not trip. I turned on the stove and it workedjust fine. I repaired the drill hole by wrapping with electric tape.
Is that safe?? Any suggestions?
Mburklow
mike_roseann@mi-connection.com
mburklow is offline   Reply With Quote
Old 07-12-2009, 07:01 AM   #2
If you drew a spark, some of the wires melted. I would either replace the cable or install a proper J box and make a splice. If this sounds like a lot of work, is you fire insurance up to date.
Old 07-12-2009, 08:40 AM   #3
Mburklow
The cable may eventually fail because of moisture wicking into the taped repair.
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 02:40 PM
Electric Boiler Merged w/ Wood Stove Radiator westphaltyler HVAC 1 03-23-2009 10:44 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Electric Stove Help tempmeo Electrical 7 06-05-2006 07:18 PM
Stove wiring? OSt8Pokes Electrical 2 03-01-2005 05:53 AM
