-   -   Electric Stove Wiring (http://www.diychatroom.com/f18/electric-stove-wiring-48666/)
mburklow 07-11-2009 09:12 PM
Today I was putting some OSB in the attic and I drilled a deck screw into the wire foir the electic range. There was an spark but the breaker did not trip. I turned on the stove and it workedjust fine. I repaired the drill hole by wrapping with electric tape.
Is that safe?? Any suggestions?
Mburklow
mike_roseann@mi-connection.com
Just Bill 07-12-2009 08:01 AM
If you drew a spark, some of the wires melted. I would either replace the cable or install a proper J box and make a splice. If this sounds like a lot of work, is you fire insurance up to date.
Yoyizit 07-12-2009 09:40 AM
Mburklow
The cable may eventually fail because of moisture wicking into the taped repair.
